ML320 P300 code, HELP
Old Oct 13, 2017 | 04:45 PM
elalto's Avatar
2002 ML320 W163
Hi All,
I have a 2002 ML320, the truck was running really well when all of a sudden while on the freeway at 80MPH the CEL came on the truck started missing, the engine lost power, I was able to get to the shoulder. The car would start but would not accelerate and the engine was shaking and misfiring. I had it towed home and now the engine will not even start. The only codes are the "random misfiring" code. What is wrong? Help Please!
Old Oct 15, 2017 | 03:04 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The codes you posted will cause a performance problem but will not cause a no start issue or not able to move the truck.
There must be transmission codes or ESP codes that your scanner is not to read.
Old Oct 15, 2017 | 01:42 PM
elalto's Avatar
2002 ML320 W163
New Info: Changed the "Crank Position Sensor" and no change. Then shot starting fluid into it and the truck started and ran fine for a few seconds.
It now appears that I have a fuel problem. HELP still not running or starting with out starter fluid.
Old Oct 16, 2017 | 06:35 AM
Try this link that I recently posted. First replace the fuel filter and if the problem still exists, replace the fuel pump.
https://mbworld.org/forums/m-class-w...ml#post7286342
