No power on fuel pump fuse
Hi guys, i have a 2006 mercedes ml500. Fuel pump relay works well but there is no power on the fuel pump fuse. Do you know what is going on? Also sometimes i get the power and engine runing well but few minutes later engine shut down and no power on the fuel pump fuse
https://mbworld.org/forums/m-class-w164-72/
no power on fuel pump fuse
Hi Dear,
I already fixed the problem. I did connect the main power line in fuel pump's relay to out going power from the relay
then I saw still was no power in the fuse but when i removed the fuse there was a power in the fuse holder, so I took the fuse holder part and i did tight the fuse holder.
so everything works well now.
Thank you All
Thank you All
estergirl (05-15-2023)
