Transmission issue - HELP
Old Nov 6, 2017 | 05:07 PM
tzachi's Avatar
Ml320 2000
ML320 2000 (229,000 miles)
Start to drive, all fine. After a few minutes on the road, car in drive but the gas does not effect it and car slow down to stop even if still in drive. Push the gas and no move. Turn key of for 30 seconds, start the car, shift into drive and all fine. Till a few minutes later. Happened again and again. Is it the transmission gone or electric components (my hope) Transmission fluid is fine, even a bit too much.
A local mechanic said it's dead and ask for $2,200 for refurbish it.
Any help?
Old Nov 6, 2017 | 07:46 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
I responded to your problem on the other forum.
Old Nov 6, 2017 | 08:00 PM
tzachi's Avatar
Ml320 2000
Got the same handle on the other forum? I live in Mt. Kisco. Do you know a trusted shop in Westchester to replace the connector for my trans?
Old Nov 6, 2017 | 08:40 PM
You don't even know what the problem is and you want to replace parts.
Stick to one forum because I'm not going to flip flop on two forums. Post your question in the other forum.
Old Nov 7, 2017 | 03:27 PM
If you want replace the 13 pin connector, then you will have to buy one from the dealer, $15-20. And then I will send you to a shop in N. White Plains where he will install the part and clear the codes.
Old Nov 7, 2017 | 05:02 PM
tzachi's Avatar
Ml320 2000
Many thanks. Placed the order.
Old Nov 8, 2017 | 05:07 AM
Did you order it from a M/B dealer? Aftermarket one will not work.
Old Nov 8, 2017 | 05:09 AM
Please UPDATE YOUR PROFILE in USER CP to include the year and where you live.
Old Nov 8, 2017 | 05:28 AM
tzachi's Avatar
Ml320 2000
https://www.mbpartsusa.com/oem-parts...ing-2035400253
Old Nov 8, 2017 | 12:20 PM
tzachi's Avatar
Ml320 2000
Maj. Dundee,
A friend got the car up and got the connector out. When got the first part, the electric wires one, had some oil on around it. When got the housing part (the one with the 7mm screw in it) out, got around 1 quart of oil pouring out from the o-ring housing.
Waiting for new part to arrive and and than to clear the codes.
Hope this is the reason for the problem as you correctly detected and recommended to look into.
I will post this on the other forum for people to see the update.
Old Nov 8, 2017 | 02:33 PM
jwhite03's Avatar
1999 ML320 w163
Wha
what other forum? I have transmission?'s too but can't find the other forum.
Old Nov 8, 2017 | 03:03 PM
tzachi's Avatar
Ml320 2000
jwhite03, check your pm.
Old Nov 8, 2017 | 06:44 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Dont think your transmission is bad, i would change the oil and the filter, replace the conductor plate and 13 pin connector after that clear the codes. I would do that before spending 3 grand on transmission. Good luck!
Old Nov 8, 2017 | 06:48 PM
tzachi's Avatar
Ml320 2000
Thank you Igor,
See my post #10 above.
Will have the new connector next week and the scanner to wipe the codes and hope for good.
Old Nov 8, 2017 | 07:16 PM
IgorE350's Avatar
Thank you Igor,
You might need the conductor plate and if you do the conductor plate, check the solenoids on it. But yes start from the connector first it might be the fix for you. but if your ml have a lot of miles and you trying to keep it for a wile, i would do the whole thing, its worth it, took me about 3 hours to do.
Old Nov 14, 2017 | 06:30 PM
tzachi's Avatar
Ml320 2000
I am back and not good news.
Changed the pilot bushing, cleaned ATF in the connector housing case and used the AUTEL MD802 MaxiDiag Elite Diagnostic Tool to clear the codes.
Checked codes again - no faulty codes- so took it to a short ride.
First mile shift beautifully. Back home after a mile + with same problem. In drive or reverse and no move. Turn car off and on after few minutes and can drive again.
Codes that I get are as follow:
134 (stored)
135 (stored)
137 (stored)
P0720 (current)
P0700-106 (current)
Any idea what to do next?
Old Nov 18, 2017 | 10:22 PM
IgorE350's Avatar
134 (stored)
135 (stored)
137 (stored)
P0720 (current)
P0700-106 (current)
Read my post earlier, do it all and it will do away, or check ur gear shifter.
