IS MY CAR'S AC COMPRESSOR IS FAULTY OR ANYTHING ELSE
Old Nov 30, 2017 | 09:00 AM
MERCEDES.BENZ's Avatar
mercedes ml320 2001
I HAVE A MERCEDES BENZ ML320 2001 MODEL GCC SPECS..... ITS WORKING GUD BUT THE A/C COMPRESSOR SOMETIMES STOPS WORKING AND THEN THE CAR STARTS HEATING UP, LATER IF I SWITCH THE AC OFF AND TURN IT ON AGAIN IT STARTS COOLING AND THE CAR'S TEMPERATURE ALSO COOLS DOWN SO IF ANYONE CAN HELP ME OUT IN THIS MY WHATSAPP IS +971522884090 U CAN REACH ME THERE IF ANYONE IS THERE TO HELP ME ILL BE VERY THANK FULL TO YOU..!
Old Dec 1, 2017 | 12:18 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Have you checked the coolant level in the the reservoir? What color is it?
The compressor is automatically shut down when there is a cooling problem, in order to protect the compressor.
The temperature gauge goes up to what degree?
Old Dec 4, 2017 | 07:12 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
2001 ml55 amg
Oh wow, thats why i couldn't fill up my ac system with refrigerant? my compressor kick in and then after few seconds shuts off and it didnt pull the refrigerant. I was thinking its because its cold outside. had my radiator and condenser replaced did the thermostat too. and for some reason the big rubber house that comes from the thermostat feels full of air and the one at the bottom same way. Started the car let it heat up but still for some reason it feels like ther is no coolant in them houses. had my heat on on high, was working fine. Am i doing something wrong?
Old Jan 26, 2018 | 02:26 PM
Cory Ward's Avatar
2001 c320 mercedes
2001 c320
[QUOTE=Maj. Dundee;7324810]Have you checked the coolant level in the the reservoir? What color is it?
Two codes came up P0115 (Engine Coolant Temp Circuit Malfunction) P0455 ( Evap Emmissions systems). which could be possible through off sensor cause on my dash it would state "Coolant level low" after driving that would go away.But no leaking nor overheating everything is normal coolant leak was repaired in the past. P0455 I can only assume as well that it could be to my faulty and ****ty replacement gas cap, but wouldn't the warning light flash? otherwise I do not see any noticeable signs of these two codes. Drives great I have to jump it from time to time when it dies. Bu it won’t die for 2 or 3 days after jump.My car right now will crank but won’t turn over it has a pick n pull battery that doesn’t even fit the whole battery tray in it from last owner I wonder if that is the problem. I haven’t tried to jump it again yet.
Old Jan 26, 2018 | 03:11 PM
Cory, what vehicle are you asking about? If it's the C320, you are on the wrong forum.
