stop and go creaking
Old May 10, 2004 | 02:42 AM
pointman's Avatar
a car that can't do the throttle reset.
just curious if anyone else is having the creaking noise from the torsion bar on stop and going??? any solutions?
Old May 11, 2004 | 08:51 AM
TheGreat1's Avatar
BMW 328i, 2000 ML320
I think its your shock that bad. Is the noise from the rear or front side?
Old May 11, 2004 | 12:07 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Re: stop and go creaking
There's a small shim between the torsion bar and where it mounts on the frame. That shim wears through and causes the creaking noise.
Old May 11, 2004 | 12:17 PM
pointman's Avatar
im pretty sure its not the shocks, not a strong recoil feel, nor a squeal. sounds like a "brap" noise from mid to front end.
pointman's Avatar
Re: Re: stop and go creaking
will my sa know what that is if i bring it to his attention? thanks mbtech
Old May 11, 2004 | 12:25 PM
mbtech208's Avatar
Re: Re: Re: stop and go creaking
Most service advisors won't know, the technician sure will though, if he's good.
Old May 11, 2004 | 02:33 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
If you are SURE that the rear struts are not the root cause of
your noise:
Sounds like the bushings for the 'Anti-sway bar'
needs to be replaced. Over time they become brittle.
On the other hand,
I had the similar noise, the noise is gone after replacing
the struts.
What I am saying is that EITHER the struts OR the anti-sway
bar bushings are the culprits.
Good Luck !!
Old May 11, 2004 | 06:02 PM
pointman's Avatar
Re: Re: Re: Re: stop and go creaking
thanks, looks like ill have to be thorough with my explanation... thanks!
Old May 11, 2004 | 06:03 PM
pointman's Avatar
your noise:
On the other hand,
the struts.
Good Luck !!
appreciate the knowledge on the issue.
Old May 15, 2004 | 12:13 AM
mdstran's Avatar
ML 430
my dealer replaced the sway bar bushing in the front but i'm kinda wondering if i can do it my self because the creaking noise is back again
Old May 16, 2004 | 01:39 AM
pointman's Avatar
mbtech, is this annoying noise just that? or is it potentially dangerous? thanks
Old May 16, 2004 | 03:06 AM
Kar don's Avatar
Mercedes-Benz
dude how many MLs do u have? lol.
Old May 16, 2004 | 01:31 PM
pointman's Avatar
haha, in total i have owned 6, 98 320, 99 430, 00 320, 01 55, 02 55, 04 500. now i have the 00 320, and the 04 500.
Old May 17, 2004 | 12:39 PM
mbtech208's Avatar
It's not dangerous at all. Just annoying.
Old May 17, 2004 | 02:23 PM
pointman's Avatar
ahhh, talk about relief...thanks again mbtech...youre really helping me out a bunch with this annoying issue...much appreciated.
Old May 17, 2004 | 03:19 PM
mbtech208's Avatar
I do what I can. So when are you going to get it fixed?
Old May 17, 2004 | 04:08 PM
pointman's Avatar
well, the noise suddenly disappeared last night!!!! any ideas why? so, i was going to call and make an appointment today, but i wanted to wait til the noise was back with a vengeance so the dealer doesnt try to say they cant hear it.
Old May 17, 2004 | 04:17 PM
drummerboy's Avatar
Rear Shocks!
