W163 window problem :(
Old Dec 24, 2017 | 12:39 PM
omarka's Avatar
2000 w163 ml 320
Hello everyone ,
I'm new here and I really need help with my W163 ML320
I have posted a video on Youtube and this is the link :
it's a really weird problem and i haven't seen like it before, so if someone have any ideas please help me!
thanks in advance
Old Dec 24, 2017 | 02:10 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You were moving the video too fast. Can't you tell us in words what is happening?
Old Dec 24, 2017 | 02:34 PM
omarka's Avatar
2000 w163 ml 320
sure ,first the driver side window goes down with no problem ,when it's fully down i pressed the passenger side window switch as i was pushing the switch down the passenger window goes down and the driver side window goes up simultaneously (without me pushing the driver side switch) ,and you can see in the video the instrument cluster lights like a Christmas tree too when both switch are pressed at the same time
P.S.: i recently replaced the window switch so it's not the problem
Hope this clarifies the video and thank you for the reply
Old Dec 24, 2017 | 03:31 PM
What I.C lights flicker? and what year is it?
Old Dec 24, 2017 | 03:36 PM
Originally Posted by omarka
W163 ML320
Please UPDATE YOUR PROFILE in USER CP.
Old Dec 24, 2017 | 04:05 PM
omarka's Avatar
2000 w163 ml 320
It's a 2000 ML320
the BAS ESP , OIL, and COOLANT lights come on and the rpm needle goes up and down
if I restart the car everything goes back to normal and all lights off .
Oh and the lights keep flickering while the windows are moving ,once the windows stop only the BAS ESP stays on and the rpm needle settle to normal position .
Old Dec 25, 2017 | 01:15 AM
I forgot to ask this question, what happens if you started the eng. normally?
Old Dec 25, 2017 | 12:10 PM
omarka's Avatar
2000 w163 ml 320
Unhappy
Everything in the car works perfectly until I press the window switches ,but if i pressed a single switch i.e.: the driver side, the car behaves normally .
very weird
Old Dec 25, 2017 | 04:37 PM
On top of relays 17-18-19 mark what number it is. Remove relay 17 and use as tester. Remove relay 18 and replace with 17 and see if the problem still exists. Do the same for relay 19.
Old Dec 25, 2017 | 04:56 PM
omarka's Avatar
2000 w163 ml 320
will try it tomorrow, thanks
Old Dec 27, 2017 | 09:48 AM
omarka's Avatar
2000 w163 ml 320
so today I tried what you told me , the problem is still there , so I removed the relay and pressed the switch I was expecting that the window would not go down , but the instrument cluster still flashed warning lights even though the window did not move an inch ,any ideas ?
Old Dec 27, 2017 | 01:19 PM
Then it would seem that there is a wiring problem or you have a faulty fuse box.
Remove the window switch and look for any wire/s that do not look like they belong there.
If not, then pull up the fuse/relay module out of the fuse box and inspect all the many wires in there for similar wires that do not belong there.
Old Dec 27, 2017 | 01:24 PM
omarka's Avatar
2000 w163 ml 320
sounds like a great Sunday job again thank you very much appreciate it
Old Dec 27, 2017 | 01:34 PM
Remove both covers to the fuse box and then remove the 3 screws and pull it up. Inspect everything in there.
Old Dec 27, 2017 | 01:46 PM
omarka's Avatar
2000 w163 ml 320
You are literally a lifesaver I was just searching how to remove the fusebox
Old Dec 27, 2017 | 03:01 PM
Glad to help. Just ask.
