Headlight?
Old May 10, 2004 | 11:17 PM
matt5555's Avatar
Headlight?
I have a main headlight out on my 02 ML 320 (halegon, projector style). Only 27k miles yet one is out
Anyway we need to get it replaced tommorow before a roadtrip where can I get this done fast?
Old May 11, 2004 | 01:20 AM
pointman's Avatar
a car that can't do the throttle reset.
dealer...warranteed...2 minutes.
Old May 11, 2004 | 07:15 AM
TheGreat1's Avatar
BMW 328i, 2000 ML320
Pepboys, or any local autopart store sell the bulb. 5 minute job to replace the bulb...
Old May 11, 2004 | 02:39 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Don't go to Pep Boys or any aftermarket store as the bulb will most likely not match. Go to your dealer I am certain they will take care of you or your parents (Its their ML isn't it??)
Old May 11, 2004 | 02:58 PM
matt5555's Avatar
Angry
Thanks guys. I gave it a try (it really was easy) and bought the right bulb H7 55watt and changed it out. Took only 5 minutes. Of course that didn't fix my problem as the new bulb doesn't light up.
Going to have to take it to the dealership (this better be under warranty) to have them fix it when I get back then.
Old May 11, 2004 | 07:34 PM
TheGreat1's Avatar
Did you check your fuse? Because there should be one for the left and right side headlights... If one is blown it would only take like 2 minutes to replace.
