Bi Xenons>
Old May 14, 2004 | 06:33 AM
imwalkin's Avatar
ML 430
Bi Xenons>
Engisoft has them for 1049 with leveling motors??? and an additional $100 for the plugs?? that sounds too good to be true......is this legit, is it OE stuff, its not an add on kit or anything???? what else is needed to use the leveling feature???? thank you!!!!!
Old May 14, 2004 | 11:16 AM
Kar don's Avatar
Mercedes-Benz
Yea, all the bixenons have the leveling motors inside the lights, the thing is you need the axle sensors on your sway bars to make these motors work. If the axle sensors are not plugged into the lights you will not have auto leveling. Also all non-xenon equipped Mercedes vehicles do not come with these sensors or wiring from the factory.
Old May 14, 2004 | 02:19 PM
pointman's Avatar
a car that can't do the throttle reset.
basically, outlevel isnt gonna work without extensive modification.
Old May 17, 2004 | 06:22 AM
imwalkin's Avatar
ML 430
ok...so its not worth it getting those extra parts....but all in all thats a pretty good deal ..? right?
Old May 17, 2004 | 02:24 PM
pointman's Avatar
1k for new bixenons...yes. try ebay for some used ones, you never know.
