2005 ml270 steering rack replacement issues
Old Apr 15, 2018 | 05:32 AM
Tommy Tank's Avatar
2005 ml270
Hi all
I have replaced a failed steering rack on the above car and after fitting, there doesn't seem to be any assist in the steering, it's like the pump doesn't come to life, can't hear it whining at all. I've taken the pipes off the rack individually and seen fluid pumping out when I turn the wheel so I'm happy that it's getting all around but just no help from the pump. There's an esp/bas fault light in now too. Has anybody got any ideas or suggestions?
kind regards
Old Apr 15, 2018 | 08:57 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Whenever the P/S system is opened for any reason, a bleeding procedure is necessary before the eng. is started. Once it is opened, air is trapped and it must be removed prior to starting the eng. after the repair.
The two front wheels must be raised off the ground and turn the steering wheel back and forth 30+ times in order to expel the trapped air. If not, the screen in the P/S reservoir will be damaged.
File Type: pdf
Old Dec 15, 2021 | 12:25 PM
hhomere's Avatar
2005 E 500 Mercedes-benz
Question
Originally Posted by Tommy Tank
Hi all
kind regards
Did you ever find a solution for your steering problem?
Old Dec 16, 2021 | 10:09 AM
homer, this is a three year old post and if you notice that Tommy had that one post and never returned to the forum
