Help with 1999 ML430 O2 sensor replacemet
Does anyone know if the computer needs to be reset after changing these or the negative cable removed??? I have NJ inspection in a few weeks.
Thanks in advance..........Mike
Otherwise, I have installed 2 bad sensors, or something else is the problem Don't know what the next step to check is.
I am hesitant to reset the ECU...............don't want to loose key fob access and or any other coding info
