Clock
Old Jun 16, 2018 | 12:50 PM
MLw163's Avatar
ML500 ML350
Clock
The clock adjustment will no longer adjust the time on my 02 ML500.
The clock works but the adjustment handle won't engage.
Has anyone else experienced this problem ?
If so is there a fix ?
Old Jun 18, 2018 | 03:34 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The only fix is to buy a used instrument cluster.
The work around fix would be is to pull the fuse for the Inst. Cluster when the clock reaches a full hour (for example 4:00) . Then return to the ML and reinsert the fuse when the time is really 4:00.
Fuse #5 in the Right Side Kick Panel Fuse Box.
Old Jun 21, 2018 | 02:57 PM
MLw163's Avatar
ML500 ML350
Thank you!
As a side note when I reinserted fuse 5 at the appropriate time the clock set to 12:00.
I don't know if this is particular to the 2002 w163 or not but I removed fuse 5 and waited to noon and reinserted it.
Old Jun 21, 2018 | 06:30 PM
Originally Posted by MLw163
Thank you!
Great.
