Window issues
Old Jul 23, 2018 | 08:17 PM
BlackLung214's Avatar
ML350
Window issues
Hello all,
have a question, my driver side window goes up half way on auto and than back down.
I had had the opposite issue where it went all the way up and then half way down. I fixed that by the reset procedure, however in current case it’s not working.
So again, window is open, I pull the button for auto close, it goes up only half way, then back down to full open.
thanks!
Old Jul 24, 2018 | 04:45 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Your system is reading an obstruction and the obstruction is that the rubber trim on both sides of the window are dry.
When the window is going up, press the button again to cancel up and it will stop. Then spray WD40 on the inside and outside rubbers and glass and then try to open or close window. Clean up later.
Old Jul 24, 2018 | 07:30 AM
ML350
Thank you! I will try it and let you know if it works out!
