2000 ml 320 door lock relays
2000 ml 320
Hi, I had my ml 320 in the shop for battery drain. When I got it back my locking sequence is out wack! When I open driver door only it unlocks, when passenger opens door, all locks open! I know trying to find the battery drain fuses and relays were pulled one by one. My question is are the F15 F20 F23 F24 relays interchangeable or only the correct relay would fit in each spot. wonder if I swap them around right it can return to the right purpose, driver door only control all locks opening.
thanks in advance
thanks in advance
