2002 Ml320 Water pump w163 - 3 different ones
Woke up and had some anti freeze on the drive way, drove it on ramps and all I could see was a few drops on the lower radiator hose. The problem is there are three different water pumps, two hose, three hose and optional oil cooler line.
This is my vin 4JGAB54E92A323859, Can someone tell me which waterpump I need and ones to stay away from.
Thank you.
Thank you.
Thanks for your help. This must be the most frustating part ever, locally they want about $170 for the part but I have to bring it in, online I wanted to get it with prime 2 day shipping but it shows that both with oil filter fits my suv. and without oil filter fits my suv and the same for ebay. Went to pellican parts it says my suv don't have the oil tube. Is there a way to visually tell for certain if I have the oil filler tube?
00 C200 & 00 C55 & 06 SLK55
Your "W163 Ml320" doesn't has oil cooler, for that your water pump oil port is blocked out..![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
http://www.benzworld.org/forums/w163...ater-pump.html
-;ZAYED;-
-;ZAYED;-
You;re the man thank you, I have not did this before and got conflicting information from sellers even as recently as a few hours ago said don't worry that I do have the oil cooler.
Ever have a day when everything goes wrong? I don't have them often but today was definitely one. One of the bolts broke off in the engine on the lower part of the water pump. How doe I get it out?
Thanks. Dennis
Thanks. Dennis
Please stick to one thread. I have already responded to your original post.
https://mbworld.org/forums/m-class-w...002-ml320.html
