front lower control arm replacement
Old Sep 4, 2018 | 03:25 AM
alexa67's Avatar
ML320
Surprised at how little I have found about replacing front lower control arm on 2001 W163. It appears simple enough. Release tension from the torsion bar. Then remove the through bolt where the arm is attached to the frame and release the lower ball joint from the wheel knuckle. Finally, it appears to me that the third "corner" of the control are slides into a socket on the front end of the torsion bar. I am hoping with rest of the control arm detached that it will just slide out and the new one would slide back in -- without pounding or pressing. However, I have not found anything that confirms how the control arm is attached to the end of he torsion bar. Any one have experience with this?
Old Sep 4, 2018 | 07:02 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here is your confirmation.
Old Sep 5, 2018 | 12:05 AM
alexa67's Avatar
ML320
Thank you. It is a good diagram but I am still unsure how the far back corner of the torsion bar (the end that is hex-shaped stud that fits into the hex-shaped socket, part #160) (I am referring to the end that is not clearly pictured hear and is behind the shock in the diagram). If it simply slides in and then I attach the frame bushing and lower ball joint then this is simple enough and I think I will go for it. But if it is complicated, such as it must be pressed out/in then I may re-think this.
Old Sep 5, 2018 | 08:25 AM
Exactly what is your problem and what do you propose to do?
Old Sep 5, 2018 | 10:34 AM
alexa67's Avatar
ML320
Remove and replace the lower control arm. The lower shock mount bolt broke off. I attempted to drill it out and after getting about 3/4 of an inch into it I started to tap out threads so that I could insert a bolt inside of the broken bolt to (hopefully) screw out the broken bolt. However the tap broke off too and after spending hours on this problem I am ready to just replace the lower control arm.
Old Sep 5, 2018 | 03:47 PM
Get a used control arm but check it for broken bolts.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 6, 2018 | 01:40 AM
alexa67's Avatar
ML320
This is very helpful information. Also, good point about the used part. I have since found a used OE part.
Thanks for all your help.
Old Jan 9, 2019 | 04:14 PM
benzreyes's Avatar
ML55 AMG
Thumbs up
THANK YOU Maj. Dundee! I had the same problem with my shock bolts snapping off and the extractor broke off as well.
I took everything off and was ready to pull the lower control off and I felt tension and figured I should research a little more before I continued. You sir may have saved me a hospital visit!
Old Jun 10, 2021 | 04:59 PM
Gunning24's Avatar
2003 ml320
I hate to resurrect this but its one of the only posts on this when your search google.
I'm close to as far as you got but like you before I start loosening lower control arm bolts I'm reviewing.
Do you really have to release tension from the torsion bar bracket before you take off the front lower control arm even if its jacked up? In every torsion bar video i watch there doesn't seem to be any tension on the torsion bar when they loosen the torsion bar bracket bolt when its on jack stands.
I was about to start following the service manual's step by step before I read this... It fails to mention anything about.
Old Mar 15, 2024 | 07:20 PM
ChrisVannoy's Avatar
2002 Cl500
To confirm yes you have to remove torsion bars before removing lower control arms….its the first thing you should do then follow sway bar, upper control arm, otter tie rod, knuckle ball
joint then lower arm bolt
Old Sep 12, 2024 | 02:42 AM
Olamidefx's Avatar
Clunking noise driver side
Please guys i need help with the clunking noise on the driver side, i have changed the stabilizer swar bar bushing but still hearing that noise, so i disconnected the stabilizer link and drive around noise wasnt there anymore, if i connect the links again the noise comes back up. What's the solution to this please
Old Sep 12, 2024 | 02:36 PM
2002 Cl500
the link between the sway bar and the frame also has two rubber bushings I would inspect that as it’s probably no longer there. It’s the two brackets that the way bar connect to in the middle that then connect it to the frame, where that connection happens to the frame those bushings can blow out pretty cheap and easy fix new brackets and your on your way again mate! Post results let us know how it turns out Por favor. Happy motoring
