skyview problems
Old Jun 14, 2004 | 04:30 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Unhappy skyview problems
Just got the call from my independent dealer saying that the ML was finished.
I had asked them to checkout the rattling from the rear of the cabin, which they found a few bolts missing but they replaced and it's better now.
BUT, the big thing is that they also found when test driving that the entire skyview assembly is loose, which is causing the rattling up top. I was quoted 4-5k to repair/rebuild the entire skyview assembly
Old Jun 14, 2004 | 04:38 PM
andaya's Avatar
99 ML 430
Unhappy WOW! I have the skyview....
And hope this doesn't happen to me. Is there a way you can tighten the loose joints/bolts?
What I do is every other month I just greese the ends and joints and have a trouble free skyroof.
Good luck.
Old Jun 14, 2004 | 06:03 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Re: WOW! I have the skyview....
Good luck.
They said if they started taking nuts and bolts off the skyview assembly, it would mis-align everything else, resulting in the rebuild of the entire assembly. They said it was poorly built by MB. They did what they could, greased the bolts and such. It's a little better, but the rattling is still there
Old Jun 15, 2004 | 12:46 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
This was allways a troublesome option and is high maint. It has not been offered in some time. My dealer pretty much refused to sell them. ML's with this option usually go for less than the std sunroof or no sun roof. This also holds true at wholesale dealer auctions. If yours has not broken yet, be patient, it will and it will continue to break.
Old Jun 16, 2004 | 04:10 PM
autogunner's Avatar
You can tighten it but you have to drop the headliner, they were not installed any after the 2000 model because the window curtain "airbags" . were added as a standard feature and their is not enough room in the roof area for both,that is why you can't get the skyroof anymore. Autogunner.
Old Jun 17, 2004 | 06:34 PM
mihir_d's Avatar
2000 ML320 2006 SLK 350
4 years of skyview use on my 00 ML320
Have had no problems with it....works in excellent condition..never stuck on me...never rattled, never leaked...
For me, its one of the best features on my ML...
Old Jun 18, 2004 | 12:47 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
ours has never given troubles such as getting stuck, not operating, leaking, etc. Only rattling a little now I guess, but since they greased and tightened up what they could, it's MUCH better now.
Still one of the best features on our ML as well
Old Jun 18, 2004 | 01:34 AM
pointman's Avatar
a car that can't do the throttle reset.
Re: skyview problems
its a well known issue...thats why mb stop making them so soon. supposedly they are full of issues, are hhurt the structural integrity of the ml.
Old Jun 18, 2004 | 01:37 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Re: Re: skyview problems
yeah, it is. so far we've been lucky I guess...all is well, except for the few rattle spots, but much better than before
Old Jun 18, 2004 | 07:28 AM
amb9800's Avatar
2002 ML320
Yeah, that could be a factor, but the main reason behind MB discontinuing the Lamella (SkyView) roof was that it is incompatible with the curtain airbags installed on later ML's.
Old Jun 18, 2004 | 11:52 AM
pointman's Avatar
Re: Re: Re: skyview problems
where did you hear that? according to my sales rep and from brabus the skyviews a problem and structurally unsound.
Old Jun 18, 2004 | 01:01 PM
mihir_d's Avatar
It was the curtain airbags that forced MB to discontinue the skyview..
The skyview is not compatible (safe) once the curtain airbags were introduced..that's what forced MB to discontinue it.
Interestingly, the skyview was conceived specifically for the Jurassic Park movie...vehicle...and then MB later on decided to offer it as an option..
Once the curtain airbags came, the skyview had to become history..
Old Jun 18, 2004 | 01:12 PM
andaya's Avatar
99 ML 430
Unhappy Yep, then sure enough came the Cadillac SRX...
With the skyview option...D'oh
Old Jun 18, 2004 | 05:57 PM
mihir_d's Avatar
That's another car manufacturuer & skyview manufacturer...
With the MLs though, it was definitely the curtain air bags that caused the demise of the skyview option..
It is likely, that it gets reintroduced in the W164, once MB too figure out (like Cadillac)...how to make the roof compatible with the curtain air-bags..
Old Oct 12, 2004 | 01:51 PM
redhot0310's Avatar
99 ml430
help
99ml430 with sky view problem the unit will not open and get a bad clicking/grinding sound when i push the button to close it ........ any ideas?
Old Oct 12, 2004 | 03:26 PM
Kar don's Avatar
Mercedes-Benz
needs replacement@!
Old Oct 12, 2004 | 04:09 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
could be the motor/gear...someone posted a DIY on that. They tooks pics of the gear teeth and gunk all over it so it slipped and didn't catch thus not opening the skyview. The motor is in the trunk, where the light panel is. Take that off and you should see the motor there I believe...do a search for skyview repair or the like.
good luck!
Old Apr 5, 2007 | 09:03 AM
My ML's Avatar
l sl 7.3 koenig l cl 7.3 koenig l Ml 350
i owned an ml320 with skyview and there was no probelms with it and owned it for 6 years
