Transmission Fluid change, how many Liters?
As suggested by many on this newsgroup, yesterday I changed
the transmission fluid (removed the pan, cleaned the pan,
cleaned the area where the gasket is, removed the filter,
put new filter, put new gasket, and then I put 2 liters of
Mercedes-Benz Transmission Fluid in the pan, then I put back
the pan carefully and put the bolts on. No leaks.
Since this truck doesn't have the dip stick to measure
the transmission fluid, I couldn't verify the amount of
fluid I put in is ok ? Does Bentley manual say how many
liters need to be put in? I won't drive the truck until
I am sure.
One solution might be to go buy the dip stick. Is that what
you guys (would do) did ?
Comments/suggestions are appreciated.
Phanendra
is available at the dealership for $59).
Those who have changed your transmission fluid, how many
quarts/liters of fluid did you put in after the fluid+filter change?
Phanendra
Obviously, I didn't do that.
About 7.9 quarts, when we open the pan, I dob't believe 7.9 quarts
of transmission fluid comes out. From the fluid that I collected, I dind't
think 7.9 quarts came out.
I guess best way to be sure is to get a dip stick. By the way, I did
order it on-line for $35. It should come in tomorrow. I will let you
guys know what the dip stick will tell me ;-)
later...
1. Drain Trans pan (Measure fluid lost).
2. Remove and clean Trans pan (including magnet).
3. Replace Filter and Gasket.
4. Replace pan.
5. Refill amount of fluid lost via dipstick/fill tube.
6. Shift through all gears (at idle), then check level at operating temp (in Park, with dipstick that I bought).
Does anyone have any strong feelings on me skipping the Pilot Bushing? I don't want to mess with it, since it's not giving me any trouble. This is more of a routine maintenance thing.
