1999 ML320 Shredded belt
It was running great for a series of test drives for 50 miles or so. Then I accelerated pretty hard to see how it would do, and the belt came off and shredded. I'm in the process of checking everything now. There are no pulleys obviously broken this time. I've read that the harmonic balancer can fail over time so I plan to replace it as a matter of course, even if it wasn't the cause of this. I am also going through each pulley and checking to make sure there is nothing seized, nothing broken and no slop.
Is there anything that makes obvious sense to check since it came off during hard acceleration? Is there anything else I should change as a matter of course (fan clutch, tensioner, harmonic balancer)? Are there any potential issues with the power steering pump, water pump or alternator that I should look out for that could cause this problem under acceleration? Is it wise to replace the water pump as a matter of course, or to leave it alone if it is working? Similar question for the thermostat (if I end up replacing the pump)?
Spin pulleys 4 & 7 as fast as you can. If either spins freely, it must be replaced.
Check the others for side to side movement.
4 broke previously and was replaced. It still seems fine (passes the spin test). 7 also passes the spin test. I don't see any wobble in the crank pulley. No noticeable slop in the PS, AC or generator. Not sure what else to check at this point. Guess I'll put on the new belt and try it out.
I have a belt tensioner pulley that I bought along with the idler pulley that broke. The tensioner itself seems fine, but I am not sure how to test it other than the spring still feels strong. Do tensioners lose spring strength over time or can they bind? That is a part that isn't too expensive so I could change it if it might be a problem.
I've idled it for 10 minutes and then driven it for 20 miles stop and go on surface streets with the new belt with no issues so far. I'm going to try to look for vaccuum leaks this afternoon.
https://www.gates.com/us/en/power-tr...-pulleys/c/141
https://www.amazon.com/Gates-38174-B...r=8-1-fkmrnull
https://www.amazon.com/Gates-38082-T...r=8-1-fkmrnull
Why can't you research it yourself? Why do I have to tell you about it?
https://en.wikipedia.org/wiki/Gates_Corporation
How long was your tool? Mine seemed to be pretty tough with a decent length ratchet on it.
Oh also there's a cool video on YouTube about replacing the grease with good grease in these pulleys (they typically are filled with the cheapest grease) to make them last an extra long time.
One possibility is when the belt was put on the first time it wasn't all the way put on. Like one spline off. I've seen this happen before, it's hard to tell because the chaff at the back of the belt hides one of the grooves sometimes.
Another possibility is that the water pump or power steering is about to go. It could be tensioner pulley.
I once let my tensioner pulley bearings get so bad it eventually sized up, broke the center out of the tensioner plastic tensioner pulley and threw the belt.
Seen a mb throw a belt and then about 500-1000 later it threw the belt again because the power steering pump "had just seized" (and some how lost its fluid, I didnt work on this car but I fail to see how the mechanic couldn't tell...he claimed the belt was thrown the first time because of an idler or tensioner pulley..maybe he never filled the pump up with fluid)
Also it could be the water pump, if it's still neiwsh/ super good the thing should be pretty tight with a tiny bit of resistance.
It's hard to tell with bearings because you have to put them under load to really feel how good the bearings are.
Oh and the thermostat I believe you can change without removing the belt, but it's a pain. They seem to wear out every 100k or so. I wouldnt worry about it.
A miss at idle is hard to diagnose, but mine was problems with the wires, then leaky vacuum lines, egr vacuum lines, then other ignition components like a weakening coil, crank and cam sensors, on other non ML cars I've seen bad grounds, even failing ecus, or bad electric throttle body or throttle position sensor. Bad MAP sensor, Or even the intake tube not being on all the way at the back or on the MAF or PCV plugged, leaking. I suppose fuel injectors, or fuel pump and filter though youd get extra symptoms usually.
Theres also a chance you could have a break in the wiring. With the m113 and m113 if someone drove it an extended amount of time with bad engine mounts it can cause damage to the harness.
I suppose errand voltages in the intake air temperature sensor, or even coolant sensor or the alternator regulator could all be culprits. Or even a leak in the transmission TCU plug with the transmission fluid wicking up into the TCU and shorting it out which is a problem on the m112/m113.
But don't quote me on the perhaps and maybes just throwing things out there!
Good luck and let us know if you fixed it!
Btw gator belt is awesome I have one too!
I'm very confused by your response.
Replaced the tensioner with a new one from Gates. Old one had Mercedes symbol and part number stamped on it (A1122000370), made by Litens with Litens part number 113, so I assume it was original. The new tensioner from Gates was stamped Litens 0113, so literally the same part from the same manufacturer as the original from 20 years ago! I finally found some pictures of what looked like original tensioners from around 1999 and they did in fact have the metal split pulley (looks like two pulleys riveted together). I'm not sure the expected lifespan of a tensioner, but the new one feels much stronger than the original and I don't notice the same movement I saw in the original during the rough idle.
The rough idle was an easy fix. After I replaced the crankcase gaskets, I accidentally ran one crankcase vent tube over another tube when it should have gone under, which caused the air hose connector to lift up and not seal. Reversed the route of those two hoses and the connector seals and idle is rock steady again.
No more oil leaks, running much smoother with much more power (thanks to new MAF and new fuel filter), and the belt seems rock steady. I'm very happy for now.
Thanks for all of the advice. It has been very much appreciated. This is my first Mercedes and I'm learning it's quirks. It's been very rewarding so far.
Btw beware of your window switches in the 99 they tend to stop functioning often and then you have to replace the entire switch panel. You can pull off the top of the switch and the white piece inside to get access to the springed contacts to push them with something plastic like the inside of a pen.
The truck also always thinks (due to a microswitch in the lock mechanism) that the front passenger door (I believe) is always open therefore the front overhead lights stay on and so I had to remove its bulbs to turn it off lol. All the solenoid/electric motor mechanisms still work surprisingly enough however when I hit lock I just get the dreaded machine gun sound.
I've seen now that they sell little plastic pieces on ebay to fix part of the lock however I don't think that's ur problem.
You need to find a self serve pick and pull yard if you wana spend almost nothing on parts. Especially small parts
and at least a rivet gun kit can be has for as little as $20Oh also, while we're talking about the interior, beware of the rear switches and the rear cup holders. Everytime I go to the yard they're almost always broken. New passengers are almost always confused by the switches and press too hard on the wrong side and they also brake in the same way internally as the fronts. The cup holders just have such a tiny bit of plastic tab for a hinge I'm sure they'd break if you looked at them sideways. I was able to fix mine by reattaching the tabs using a dremel to shape a few spare pieces of plastic as supports and then riveting and epoxying them all together. The thing is still weak as shiet.
Oh also the brake light switch tends to break lots, part of the vent selection dial that attaches to a bicycle brake cable like thing at the top. (It can be glued too). The wire for the FM antenna tends to break too from too much repeated flexing...it brakes right at the top were it goes from the roof into the rear lift gate. I know I'm forgetting something else here.
Tbh pretty much everything on the interior or made with plastic is super fragile.
Caution long rant below:
I've always wondered as to why...
was it due to an inexperienced new automotive designer/engineer?
Was the design rushed?
Was the wrong plastic chosen,
or the plastic changed for the production vehicle?
Maybe the plastic was manufactured incorrectly,
or perhaps it dries out quickly making it brittle.
Could it be they just didn't care expecting to replace nearly all of it by 2000, two years later.
I've also entertained the idea it was done on purpose...hoping the stuff would last long enough to surpass the warranty period so they could sell you extra expensive oem parts for the life of the vehicle. Maybe the design for the switches, etc was great but the aftermarket / OEM supplier weakened them again to sell more parts.
It also might have been done deliberately to cause the 2000 and up models to have much more of a night and day difference as compared to the 98-99, in order to goad 98-99 ML owners to find it almost impossible not to want to trade in or upgrade.
That might explain why they left out so many features at first, features which had been standard on E, even C classes since the late 1980's. Even inexpensive features.
I think they thought since it was a new segment for them, any mb loyal customer who either wanted an suv or who just wanted the newest mb vehicle type, would buy one regardless of how crap it is, and the same could he said for any car buyer who was aroused by the idea of a "MB" suv.
However if they wanted to attract E or C class buyers away from their car purchases and leases, the truck would need to be nicer and have everything plus more as compared to those cars. Hence the innumerable changes in 2000/01/02, etc.
Very sneaky.
I wonder how many people went to buy one in 98-99 and thought they'd hold off when they realized it didnt have auto dual zone climate control, no valve to prevent hot coolant from warming up the a/c evaporator your HVAC unit, no folding mirrors, no headlight washers, no HID's or advanced headlights, no heated windshield washer fluid or nozzles, no seat memory which is on a minimum way adjustable seat, no steering wheel buttons, no automatic lengthy antenna, no chrome door sills, no hood struts, no tool kit, no single articulating wiper, no tweeters, no suspension leveling or shock adjustment, no mechanical differential lock(s) no aesthetic soft door side-air bag cover, no backup sonar, no main electric radiator fan, no lower body cladding, no compass, no good sun visors.
I wonder how many people also stayed away when they noticed the undersized brakes, the lack of skid plate on the fuel tank that hangs down and is in the way for virtually all obstacles, the back seats that get stuck down all the time, the sound of leaky door seals, and the road noise from barely any sound deadening, how so much of the interior was plastic, thin, weak, and gross and the whole thing is a rattle box not to mention the bumpers and front grill are barely attached and can make all sorts of noises.
