I have the serial number, can someone confirm radio code?
Old May 2, 2019 | 12:03 AM
BeachFreak's Avatar
Slk 280
the vin checked out as 46312 which isn’t working
so I pulled the unit and here is the serial number- can anyone confirm the radio code?
thanks in advance
Old May 2, 2019 | 12:09 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Call M/B with your vin# ready and they will give you the code.
http://mercedes-benz.custhelp.com/ap...-my-vehicle%3F
Old May 2, 2019 | 04:18 AM
BeachFreak's Avatar
Slk 280
I called a dealer and gave them my vin, and they told me the code was 46312 but when I enter the number nothing happens... either its a broken head unit or maybe it was replaced at some point; which is why I was trying to see if the serial number on the head unit would turn up a different code.....
Old May 2, 2019 | 07:49 AM
Are you using the correct procedure?
File Type: pdf
Old May 2, 2019 | 02:54 PM
BeachFreak's Avatar
Slk 280
Thanks Major, I follow the process of entering the code then pressing the "OK" soft key, and nothing happens. The soft key doesn't work. So I think the head unit is faulty at this point, I was just trying to be thorough about the code.
Since the head unit gives no response to the "OK" key, I will have to find a replacement. Is there a double din compatible unit on the market that slots right in and works with the existing amps and speakers?
Old May 5, 2019 | 12:23 AM
fabbrisd1's Avatar
A gaggle of MB's
With a Metra harness/adapter and a double-DIN - preferable with Pre-Out Voltage 3V+ to properly "drive" the system in your car.
Old May 5, 2019 | 03:24 AM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
Use the search function.
Old May 5, 2019 | 11:36 AM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
BeachFreak,
Did you give the dealership a serial # for the radio itself (since the original radio may have be swapped out)?
Did you check for it in your owner's/user's manual (if it cam with your suv)? - it may have been written in there...somewhere
Old May 7, 2019 | 10:52 PM
BeachFreak's Avatar
Slk 280
Solved!
I paid $100 to pull this deck from a 2002 that was being sold for parts- sounds great !!
