Aftermarket headunit in an ML?
Anyone know if a DOUBLE-DIN unit can fit in the ML?
Thanks!
Thanks for your response.
Can I ask you about your H&R Springs and Bilsteins? How is the ride compared to the stock suspension? I'd like to lower mine as well but I don't want to fear driving in New York City or on bad roads in general. The ML is going to be bought for those reasons and I don't want to turn it into another car which I fear driving on un-smooth surfaces. What are your thoughts and how much did it lower it?
Thanks!
Thanks!
-s-
Thanks!
I think the H&Rs lower about 1.25". The ride is definately firm/rough. The shock doesn't seem to be able to absorb the weight (doesn't seem to be designed for lowered applications). If I drive about 5 MPH and go over a speed bump that is about 4 inches high, it will hit the bump stops in the front. I did not turn the front torsion bars where the front is lower than the rear-I kept it all even with front and rear. Pot holes are a "no-no".
