Steering Jabs only while turning
PS does not jab at low speed or in park like other posts. It's clean through and through sitting in driveway or cornering in town.. very faint wobble at certain speeds (40km and 110km) like alignment would cause. Not bad though.
Front end specialist w/ wheel alignment shop will find the problem.
You do realize that the ML airbags expire 15 years from the date of manufacturer.
You can find this information on the door sill.
Any input on my problem would be helpful thx
Front end.... Torsion bar shims? Steering rack bolts?
I hate guessing on these types of issues dealing with sounds from the front end.
edit: hope it's not the rack. R&R is $$$
Starting 2002 MLs, the airbags have no expiration dates....but it is known by many, that the removal of expiration date was merely awaiting certification...most airbags after 1995 (on all manufacturers) already had the technology on the explosive charge to not need replacement.
Also Airbags are part of SRS (Supplemental Restraint), seat belts are the primary safe guard. But you are right overall, I would definitely factor that in, if purchasing a 15 year+ old ML today....
The story with Mercedes Benz vehicles & airbag expiration date stamps explained in greater detail here...
