ML320 Bose radio won’t take code
Old Jul 30, 2019 | 05:50 PM
luvdubs's Avatar
2011 E350 4Matic wagon
I’ve verified the code at two dealers, but can’t seem to find anything by searching about the code entry procedure. Radio flashes CODE, C flashing. I enter all 5 digits and the first number flashes. Can’t figure what to push to verify the code. I tried SCAN, MODE, power button, SEL, WB. I surrender. Help!
Old Jul 30, 2019 | 06:15 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
This procedure does not work?
OR this one.
Old Jul 30, 2019 | 06:20 PM
luvdubs's Avatar
Originally Posted by khomer2
No. I don’t have a SEEK button, and the SCAN button just sends me back to either flashing CODE or the dreaded WAIT
Old Jul 30, 2019 | 06:30 PM
khomer2's Avatar
seek or scan button are the same thing/function.
Strange, then the radio code must be incorrect? (thinking aloud here) :|
For the 2nd link I provided, you've read the entire procedure - It may have locked you out for a time period depending on how many attempts you have tried.
Old Jul 30, 2019 | 06:42 PM
luvdubs's Avatar
The real kicker is that I have an identical head unit that was working. After a battery disconnect neither head unit will take its respective code. I now have two Bose head units, neither of which will take the code I was given for it.
Old Jul 30, 2019 | 06:45 PM
khomer2's Avatar
You may need to keep the din unit connected for power until it cycles thru the time protection and then try the radio code again.
Old Jul 31, 2019 | 04:28 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Prior to this problem, did you ever disconnect the battery?
Have you ever successfully entered the radio code?
Old Aug 2, 2019 | 12:19 PM
luvdubs's Avatar
I have, but my son lost that code. I’ve now called 5 different MB service departments and have been given 5 different codes for the serial number on the head unit.
Old Aug 2, 2019 | 01:59 PM
Call M/B directly.
Old Aug 2, 2019 | 07:55 PM
luvdubs's Avatar
Thanks for the help! The sixth dealer I called, Mercedes Benz of Chicago gave me a sixth code and it worked!
