2002 ML500 Limp Home Mode
Old Nov 2, 2019 | 10:30 PM
DaveenBavari's Avatar
2006 Mercedes-Benz E320 CDI
I have a 2002 ML500 and it goes into limp home mode after I turn it on and drive it for 8 minutes. When it goes into limp home mode a bunch of lights light up on the dash. It drives perfectly fine before it goes into limp home mode. If I pull aside, put it in park, and restart it, then I can continue just fine for another 8 minutes. I checked the 13 pin connector, but it’s dry. I have code P0720, P0600, and P0730. What might this be? The conductor plate has also already been replaced.
Old Nov 3, 2019 | 01:39 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Look at highlighted codes on pages 12 & 13. It indicates that there is a problem in Trans. Control Module and codes must be read in that module.
Reading the codes in the Trans. Module will determine what speed sensor is at fault.
File Type: pdf
File Type: pdf
Old Nov 3, 2019 | 08:11 AM
How do I read the codes in the transmission control module?
Old Nov 3, 2019 | 09:52 AM
Since you posted codes in the ECM, I presumed you had a scanner. A code reader will not do.
Amazon Amazon
