99 ML320 engine hestation
Old Jan 23, 2020 | 08:50 PM
JP2085's Avatar
99 ML320 AWD
I have a 99ML320, It idles smooth when in park, but once i drive it for 5-10 mins it wants to stall or hesitates. It showing a P0400, P0105. If its a bad EGR is it possible to unplug it and drive it. Since i am trying to get it home.
Old Jan 23, 2020 | 11:12 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
It's most likely clogged and needs either cleaning or replacement.
https://www.quora.com/How-does-EGR-b...r-car-s-engine
Essentially, NOT good for the environment if you do so.
Old Jan 24, 2020 | 12:25 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
For code P0105, check the wiring at the MAP sensor.
Old Jan 24, 2020 | 01:46 PM
JP2085's Avatar
99 ML320 AWD
OK my other question is there a temp fix like disconnecting the vacuum transducer or a vacuum temporary so i can get home then check everything.
Old Jan 24, 2020 | 04:15 PM
You could but it is in the back of the engine.
File Type: pdf
Old Jan 26, 2020 | 07:01 PM
JP2085's Avatar
99 ML320 AWD
Smile
With luck i got it home, the EGR vale had dry rotted hoses was ok and the pipe was plugged. Can the EGR pipe be cut down or shorten? The part that goes into the manifold.
Old Jan 26, 2020 | 07:05 PM
khomer2's Avatar
Nope.
If life were that easy.
https://www.benzworld.org/threads/ch...today.1414892/
