Ecu pinout
Old Apr 18, 2020 | 10:40 PM
Josh1216's Avatar
1998 Mercedes Ml320
Ecu pinout
Would anyone be kind enough to help me out with a wiring diagram for 2000 Ml55 with me 2.0 ecu?
Really need the ecu pinout diagram. Thank you
Old Apr 19, 2020 | 02:49 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here it is. But I warn you that any testing you have in mind should only be POSITIVE & NEGATIVE. Anything else could destroy the ECM.
File Type: pdf
Old Apr 19, 2020 | 08:58 AM
Josh1216's Avatar
1998 Mercedes Ml320
Thank you so much.
I'm wiring in a standalone ecu. No worries fryng the ecu lol.
Old Apr 19, 2020 | 09:16 AM
Josh1216's Avatar
1998 Mercedes Ml320
Unfortunately that is the m112 engine. I need the one for the m113.. Would you happen to have that one?
Old Apr 19, 2020 | 01:39 PM
Here is the wiring diag. legend & connectors
File Type: pdf
File Type: pdf
File Type: pdf
Old Apr 19, 2020 | 02:25 PM
Josh1216's Avatar
1998 Mercedes Ml320
Perfect! Thank you so much!
Old Apr 24, 2020 | 12:52 PM
airlenny1's Avatar
2000 ML 55 amg
Hi Maj. Dundee,
Great links for electrical. I have the same vehicle and wondering if you know which connector coming out of the ECU provides power to the fuel pump? I have no voltage at the fuel pump and all 3 wires there are in continuity with ground, so obvious short to ground somewhere. I cannot tell from the WHIP drawings which circuit goes to the fuel pump.
Thanks,
Mark
Old Apr 24, 2020 | 02:40 PM
Originally Posted by airlenny1
Hi Maj. Dundee,
Thanks,
Mark
I'm working on that as soon as you post your vin#.
