Removed ABS PUMP motor and by mistake the bushing . Need help
Old Apr 21, 2020 | 02:53 PM
irokdastar's Avatar
2004 CLK 500
Hello Everyone I have a 2002 ml500 . The motor on the abs pump was going bad so I removed it to replace the brushes . By mistake I actual pulled out the roller bushing that's inside the abs pump and now I can get it back in . There are 2 plungers that come together to hold the bushing but I cant get them to separate to get the plungers but they keep snapping back together . Is there a set screw or something that will release the pressure ? i appreciate any help . Thank you
Old Apr 21, 2020 | 08:10 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Measure the width of the hole and buy a short piece of PVC tubing slightly shorter than the width.
Insert the tubing which will push in the two pins, then insert the bearing and pull the tube out.
Old Apr 21, 2020 | 08:19 PM
irokdastar's Avatar
2004 CLK 500
my issue is trying to keep those pins open long enough to do so . I can use a screw driver to open it but I have no room to get something inside before they close again .
Old Apr 22, 2020 | 04:41 AM
Then you will have to figure it out on your own.
Old Jan 4, 2025 | 09:22 AM
jakebrake's Avatar
2007 R320
I had the same problem. I got the roller bearing installed back in eventually. I inserted a snug fitting dep well socket into the bearing and added a short extension for leverage. I held one pin open with a thin screw driver, then used the bearing to wedge open the other pin and worked the bearing into place. It took a lot of attempts and fiddling, but it only has to work once.
