ML430 steering issue
Old Nov 14, 2021 | 10:22 AM
BECKMBA's Avatar
ML320
I recently purchased a used 1999 ML430 with multiple issues. One of which is the steering will very hard to turn. I checked the fluid and it has plenty. So I jacked up the car and turned the wheel from side to side and it turns smoothly with no issues. Would this be a bad power steering pump ? The pump is not whining.
Old Nov 15, 2021 | 10:13 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
With out the eng. running, jack it up again and remove the reservoir cap and slowly turn the wheel from lock to lock. Have someone look into the reservoir and see if there are any bubbles. If so, continue turning lock to lock ( poss. 20-30 times).
If the bubbles remain you must replace the reservoir and not the pump.
Old Jan 20, 2025 | 09:30 PM
RussG's Avatar
2008 ML550, RotorWay JetExec
Sorry - wrong forum; I reposted in the W164 forum.
Dear Maj. Dundee - I would like to revive this thread. We had conversations a few years ago when I was having pump problems. As it turned out, I made a testing apparatus which determined the problem was in the rack. I replaced the rack and everything was fine - until today.
I was in a very tight parking spot and had to go back and forth to "wiggle" out. To do so, I had to turn the steering wheel lock to lock (softly - not hard lock) several times. I heard "funny" noises that I remember were steering related and then I felt the steering get very stiff. A few minutes later, all power steering was lost. I checked fluid level and it was a bit low but not by much.
So what do you think? Pump or rack? Thanks.
Old Jan 21, 2025 | 04:14 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Sadly, I think Major Dundee is no longer with us. Hope Im wrong. His advice was sharp.
Old Jan 24, 2025 | 01:39 AM
mihir_d's Avatar
2000 ML320 2006 SLK 350
Correct, our beloved Maj. Dundee is no longer with us....
