Question About 2003 ML320 Headlight Range Adjustment
I have a 2003 Mercedes ML320. On the passenger side of the lower A arm, there is a little bracket with a rod connected to the front axle sensor for the Headlight Range Adjustment. The little bracket that bolts to my A arm is cracked and I need to replace it. I had the same issue on another ML320 I owned a couple of years back. Does anyone have a diagram for the front Headlight Range Adjustment system? I just need the MB part number for that little bracket that bolts to the A arm.Thanks!
