Headlight problem
Old Oct 19, 2020 | 12:28 PM
Sprenk1's Avatar
1998 Ml320
Headlight problem
Hi, I have a 1998 Ml 320, this issue is with the headlights both low beam and high beams. When I try to turn them on nothing happens, no light comes on even when I flip the high beams. But if I hold the high beams they just work. Also I noticed that when my left turn signal is on the headlights work as they are supposed to. Please help
Old Oct 19, 2020 | 05:46 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
No mention of what type of bulbs.
Check to see if your low beam bulbs need replacing. Swap them with ones that you know are good.
Check the fuses - fuse chart is under the fusebox lid (under the hood) and the other in the passenger footwell - side kick panel.
Check the relay too for the headlights.
Old Oct 19, 2020 | 10:32 PM
Sprenk1's Avatar
1998 Ml320
The lights are just the halogen ones. The bulbs seem to be good since with the left turn signal and headlight switch on they work, other than that the don’t light. If the fuse was bad, they wouldn’t light at all at any case, right?
Old Oct 19, 2020 | 10:44 PM
khomer2's Avatar
Go thru this procedure
Old Oct 19, 2020 | 11:03 PM
Sprenk1's Avatar
1998 Ml320
okay will do in the morning, how likely is it to be the combination switch?
Old Oct 19, 2020 | 11:25 PM
Sprenk1's Avatar
1998 Ml320
Will do in the morning, how likely is it that it’s the combination switch ?
