Need help ml550 air struts
https://mbworld.org/forums/m-class-w164-72/
Secondly, please update your profile to include the year, model and where you live.
Thirdly, did you follow the instructions to a T, especially the highlighted steps?
can you tell me the proper forum to ask this question? Figured under M class would be correct as it is a ML 550
i don’t have any fancy star diagnostic system. Is there any way to work around that?
first I took off the drivers side Airmatic level sensor the side that’s filling with air. I connected it to the passengers side in hopes playing with the Airmatic level sensor arm would trouble shoot that maybe the passenger side was shot. With it all the way up it didn’t kick in the compressor like it did on the drivers side. Playing with the arm on the DR. Airmatic level sensor moved the headlights up and down. Now the confusing part, I then took the passenger side Airmatic level sensor and connected it to the drivers side and it also adjusted the headlights level but it would not adjust it or do anything when it was on its proper side. More questions than answers.
