Interior cloth coming loose
Old Aug 29, 2004 | 02:22 PM
phrak9's Avatar
90' Porsche 964 Cabrio
What is the prescribed treatment for the cloth covering coming off the pillars between the windshield and side windows? How to remove them to fix them is the real question.
--Eric
Old Aug 29, 2004 | 07:55 PM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
I would think a trip to a good auto upholstery shop would take care of it.
Old Aug 29, 2004 | 11:55 PM
pointman's Avatar
a car that can't do the throttle reset.
they pull off... open door, and remove rubber sealant... then pull.
Old Aug 30, 2004 | 05:37 AM
autogunner's Avatar
Pull down on the rubber seal that Ahopeter was talking about, then pull the apillar trim, it has a small metal clip on the side with the rubber seal and a large metal clip up by the windshield, both of these are at the top area. after you get them loose pull it back toward you and lift it up, it has three tabs that slide into the ****pit, that is it. You may want to try getting some 3M spray adhesive at walmart or autozone to spray under the cloth and then pull it tight again. Autogunner.
