No Heat. Weird problem....
Old Feb 15, 2021 | 04:46 PM
WikiTim's Avatar
2000 ML320
Hello everyone!
Hope you all are staying warm this winter because I am not.
I drive a 2000 ML320. I am currently having a very weird problem with it that no one can give me a proper answer to. Instead of speading all my money replacing one part at a time, Ill post about it again...
My ML does not produce heat when the outside temp is below 45 degrees F. The temperature of the air outside.....
Its very odd. It doesnt make any sense to me or anyone I've talked to. The vehicle does no overheat and it gets up to normal operating temp (80c) at a normal time so obviously nothing is wrong with the thermostat or engine cooling. The door flap actuator does need to be replaced but i have it pushed over to heat manually so that is also not the issue. Ill actually replace the actuator this spring. otherwise I am lost on this one. It blows my mind that it will not produce heat under 45f even after the car gets up to temp.
any ideas?
Old Feb 16, 2021 | 03:19 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Check your Outside Temp. Sensor and see if it is dislodged from its' holder, check wiring.
File Type: pdf
Old Feb 16, 2021 | 08:26 AM
WikiTim's Avatar
2000 ML320
My outside temp sensor works accurately. However i dont understand why the outside temp sensor would cause a problem with the car making heat??? Please explain.
Old Feb 16, 2021 | 09:30 AM
Although the sensor is for the A/C, I thought it could be a possibility.
Is your coolant circulation pump working with the key on?
Old Feb 16, 2021 | 01:15 PM
WikiTim's Avatar
2000 ML320
yes. replaced it in nov. works fine
Old Feb 17, 2021 | 08:24 AM
WikiTim's Avatar
2000 ML320
any other thoughts or ideas? it was exceptionally cold this morning >_<
Old Feb 17, 2021 | 08:55 PM
Tim, I have no further suggestions. Never heard of this problem.
Old Feb 18, 2021 | 02:14 AM
I emailed a friend of mine who works for M/B and this was his response to your problem.
Typically poor circulation through the heater core.
First thing to check is temp at heater core outlet. With blower off it should be close to engine operating temperature.
By the way, are you using golden or green coolant?
Old Feb 18, 2021 | 07:49 AM
Here are a couple of threads on the same issues. Follow Witek's info who I got in touch with, he's the best.
https://www.benzworld.org/threads/no-heat.3008311/
https://www.benzworld.org/threads/20.../#post-4394160
Old Feb 18, 2021 | 07:53 AM
hyperion667's Avatar
2012 CLS63
You live in Texas by any chance?
