Timing Chain Tensioner Seal / Gasket (M113)
I have a 2003 ML500 with some oil leaks.
So far I have replaced all of the oil cooler seals.
Next, I am going to replace the oil pressure port seal (right below oil cooler).
I also want to replace the timing chain tensioner seal (next to the alternator) but I have a clarifying question to anyone who knows or
has done the job themselves.
My question:
When replacing the timing chain tensioner seal, am I able to simply move the alternator, take out the chain tensioner, replace the seal
and reinstall? Is there anything special I need to look out for when I remove the tensioner?
I have attached the WIS document I have been studying and the job seems pretty straight forward.
I would just like to see what anyone with experience has to say about this repair.
Thanks for taking the time to read!
- Max
Fairly easy. The seal will be attached to the Tensioner or inside the port, just pick it out.
Does the tensioner only install one way? Is there a guide or a notch of some sort? Or can it install anyway?
