Newbie -- 3 W163 Questions
ML320
Thanks in advance for answering what are, to most members of this community, likely to be very simple questions:
1. There is a cylindrical pump/device mounted next to the battery. Is it normal for this to run several minutes after turning the ML320 off?
2. I got PIAA H3s and want to install them as fog lights. Do I need to remove the entire headlamp assembly to get to the slots? I can pull the rubber cover off of each slot, but the it's really a tight area, especially on the driver's side with the washer fuild tank there.
3.Will it be obvious where to plug in the wire/clip for the H3s?
Thanks again.
Thanks again.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
I can only answer your first question, This device is an electric cooling pump that keeps the coolant reciculating after shut down for a little while. Purpose is to eliminate hot spots and subsequent warping of the aluminum engine components. This is completely normal
ML320
one down, two to go.
Thanks for answering my first question, sosh. :Y
Would appreciate if anybody could help with the headlamp (bulb install) questions.
THANKS
THANKS
