Coolant Temperature Sensor Bad?
Old May 4, 2022 | 07:04 PM
zer0pwn's Avatar
2003 ML350
Refrigerant pressure and temperature sensor bad?
I have a 2003 ML350 VIN number 4JGAB57E63A405447. My AC is intermittently quitting and blowing hot air. I have been keeping an eye on it with my scanner and when it happens I am getting the code B1 2/2 (Refrigerant pressure and temperature sensor). When I drill into the actual AC control module information, I am getting 10 bars of pressure on B1 2/2 and INVALID for what I assume is the temperature. I do not know if the AC is low of refrigerant or not. This only happens when it is warm outside; the sensor functions normally during colder weather and does not report INVALID. When this happens, the AC compressor is reported running at 0%, and I can confirm it isn't running because both AC lines are warm. I have attached some screenshots of my scanner.
EDIT: Realized I had the wrong thread title
My plan was to have the AC system evacuated, replace the sensor, then have the AC system refilled. Is there anything I can check to make sure it is the sensor before pulling the trigger on this? Any input will be greatly appreciated.
Old May 4, 2022 | 09:15 PM
zer0pwn's Avatar
2003 ML350
I realized I put the wrong thread title, is it possible to change this? It should be "Refrigerant pressure and temperature sensor bad?"
Old May 5, 2022 | 03:01 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
There is nothing wrong with your wording in your opening thread.
When you request A/C do the cooling fans come on?
If everything is OK, replace the Pressure sensor.
File Type: pdf
Old May 7, 2022 | 05:05 PM
zer0pwn's Avatar
2003 ML350
Hi Maj. Dundee. When I request A/C it looks like my cooling fans are not coming on. I have noticed a screeching noise from the cooling fans when they do come on, but I haven't heard it recently. I tried turning on the AC on full blast, pressing the AC button on and off, and I wasn't able to get them to come on. Should I be replacing these first? Thank you for the help.
Old May 8, 2022 | 02:11 AM
I would replace the Temp Sensor first and then deal with the fan issue.
Old May 27, 2022 | 03:14 PM
zer0pwn's Avatar
2003 ML350
Looks like the temp sensor was the fix. I had a shop reclaim the refrigerant and then I replaced the sensor and recharged it. It is working now and not throwing that code. If someone else is going to do this job, I was able to get to the sensor by pulling out both headlights and the cross brace over the radiator and getting at the sensor with a smaller crescent wrench. I didn't have to pull out the windshield wiper fluid reservoir like others.
Maj. Dundee, I haven't see the aux fans come on again anytime recently. Should I probe the wiring harness with a multimeter to see if there is voltage or what is the recommended procedure for that? I am thinking the fan motors are cooked because they have been making a squealing noise for a long time now and may have just given out.
Old May 28, 2022 | 03:29 AM
Then just replace them.
Good buys on ebay.
ttps://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw= 1635000155&_sacat=0
Old May 28, 2022 | 04:11 AM
Here are the procedures to R&I the fans.
File Type: pdf
File Type: pdf
File Type: pdf
