Washer fluid reservoir sensor
Old Jun 21, 2023 | 01:13 PM
timfountain's Avatar
W163 - '01 ML320, 155k miles and counting....
Hopefully a quick & easy question.
I changed out the rear electric pump on the washer fluid tank and whilst I was in there I noticed that the two connections on the tank for the level sensor were not connected to anything. My question is was the wiring somehow optional, or should there be 2 wires connecting to the sensor? I could not see any wires close by and I do not have a low level warning light on the dash. The vehicle is a fairly base 2001 ML 320. Thank you!
Old Jun 26, 2023 | 04:43 AM
Bezalel's Avatar
ML320 W163 2000
I have the opposite issue elsewhere, of a 2-wire connector not attached to anything... : )
