Coolant Type
Old Nov 8, 2004 | 08:16 PM
deltadude388's Avatar
School bus
Coolant Type
Hello, is the MB coolant a must have? Anyone here used after market coolant like prestone or any of the other major brands?
thanks
Old Nov 8, 2004 | 09:37 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Coolant type
thanks
I'm sure it's possible, but why? Coolant is cheap and you don't need to change it every year. If your vehicle is under warranty, I would stick with OEM fluid.
Old Nov 19, 2004 | 04:30 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
You can usae Zerex G 05. It's the same thing as MB fluid, it is approved for use by MB in their cooling systems, and it is cheaper.
Old Nov 19, 2004 | 09:07 PM
springerfever's Avatar
1999 ML430
yes, the MB approved is a must-have. The Zerez G5 is the identical antifreeze to the mercedes and quite a bit cheaper.
Whatever you do.....do NOT use Dex-cool extended life coolant. There have been numerous complaints/lawsuits regarding this stuff.
Two gallons of G5 will be plenty for a 50/50 mix and some left over........
