ML320 2003 A/C issue
Hi folks, I am a newbie here. I have a 2003 ML320. i got my Alternator replaced few years ago & ever since my A/C is not working. It is blowing ambient air. Took to a mechanic recently for A/C check. He said there is no Freon & he filled it. It still wouldn't work & he said it is Electrical problem & needed $350 to diagnose. I took it a different shop where they pulled the error codes & suggested me to take it to a dealer. Is there anything I can do instead of shelling a ton of money to the dealer?
Here are the error codes :
1) B100A - Rear Blower Motor
2) B1105 - A/C Compressor
3) B1302 CAN Communication With Lower Control Panel
4) B1303 - CAN Communication with Engine Control Module
5) B1307 - CAN Communication with Instrument Cluster
Fuses & Relays for A/C seem to work fine (Fuse 44 & the relay next to it). Do you suggest me to replace A/C compressor / troubleshoot the wiring (AAM to Relay & to the Compressor Clutch / Compressor)?
Appreciate any of your help / guidance.
thanks
-tanreddy
thanks
-tanreddy
Tanreddy,
i suggest you investigate the control panel in the car where you adjust the temps. Mine went bad and did very similar codes to yours.
good luck
good luck
Thank you Chefcct! I did a little bit of driving around. Low pressure refrigerant line is not cold after the drive & is hot (eventhough the compressor is running). Is that what you had as well? When I crank up the temperature from the knob, it blows hot air & when i reduce the temperature all the way down, it blows air with outside temperature. Appreciate your help! I will investigate the control panel tomorrow.
