How to replace the rear ML320 Ornamental Cover?
Old Nov 21, 2004 | 11:35 AM
johnnyoh's Avatar
Question How to replace the rear ML320 Ornamental Cover?
I'm having a hard time in figuring how to replace my ML320 rear left side Ornamental Cover. This cover is at the rear left upper corner from the rear light. Is there a procedure to replace it and anyone have a diagram on step to step diy? Thanks!
Old Nov 21, 2004 | 07:37 PM
saturnstyl's Avatar
Replacing this involves the use of a special "piano wire" sort of cutting wire with handles on either end. You run it down the back and saw off the old part. Remove remaining adhesive and then apply new one using special preheated adhesive. I recommend leaving this to the dealer if you want it to be perfect.
