center console rattle
Old Nov 30, 2004 | 12:20 AM
pointman's Avatar
a car that can't do the throttle reset.
has anyone had a rattle from the center console area... sounds like the "wood" is kind of rattling. any remedies out there? thanks
Old Dec 2, 2004 | 01:56 PM
zeke320's Avatar
rattle
Remove the center console screws which attach the console to the floor and insert a rubber washer on each screw and replace. This will eliminate about 3/4 of the noise. The remainder is from the plastic cover which surrounds the gear shift. It is more difficult to eliminate the noise from this cover but can be accomplished with two way foam tape if not tolerable.
Old Dec 2, 2004 | 07:34 PM
pointman's Avatar
whoa! grat advice thanks Zeke!
