2005 ML350 misfire was 1 cylinder now 3 cylinders
Old Jan 1, 2025 | 10:33 AM
GunLake's Avatar
2005 ML350.
Had a misfire cylinder 1, I swapped over the plugs and wires to cylinder 4 to see if it followed to rule them out, I did put 1 new plug in because AutoZone didn't have the ones I wanted in stock so I had to order them. But one of the ones i had pulled out looked like the previous owner had stripped it and I didn't want to risk putting in back in and not being able to get it out,
It ran worse than it did before, But the misfire moved to Cylinder 4. Moving the wires back to cylinder 1 to see if it was the plugs it started to miss on 1 and 4. Then randomly cylinder 2 started to have a misfire which I hadn't touched.
So, will replacing only 1 plug on a cylinder cause more issues?
Not sure why 3 cylinders are now misfiring, My buddy thinks I need to touch the terminals to reset the computer.
Old Jan 10, 2025 | 07:36 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
You haven't mentioned if you've scanned it for codes but I assume you have to work out which cylinders are misfiring. Check all your connections very carefully as these acars are old and the connectors can easiky have corroded. Same goes for fuel injectors. Any other codes at all?
Have a good look at the spark plug wires and maybe add some dialectic grease so they don't short out.
What are your O2 sensors saying?
Old Jan 10, 2025 | 08:47 AM
GunLake's Avatar
Thanks for the reply. Here is the update. I ended up just swaping all plugs and wires since they were believed to be all original and the car has 150k miles. (It's a friends car and she doesn't know. Shes had the car since 90k miles). That cleared up the misfires. I didn't test drive the car beforehand but there is a crazy idle when in Drive. Car shakes, I don't have a scanner, So we had a friend scanning it, who only mentioned the misfire codes. But it turns out. there was around 10 codes relating to the O2 sensor on top of the handful of misfire codes. But according to the owner of the car, This idle has been that way since 90k miles when they bought the car and so have the O2 codes. There was also a code for Intake Manifold Runner Control stuck open that showed up after driving it for 15 minutes.
Old Jan 12, 2025 | 04:29 AM
BlackML550's Avatar
Sounds like a lack of maintenance is part of the problem.
Old May 26, 2025 | 09:32 PM
Dfixit1's Avatar
2000 ML 320/95 Ford F150 4x4/Harley Davidson 03 FLHRCI in vivid black
Originally Posted by GunLake
2005 ML350.
Not sure why 3 cylinders are now misfiring, MEOy buddy thinks I need to touch the terminals to reset the computer.
H7
Mine did that. Had 5 of 6 misfires. I changed out the MAF SENSOR and addeded a can of Techron injector cleaner. That got me running right for now. Hope your Rig is that easy as well
