Broken coolant sensor.....
Not sure if this is the appropriate forum since it's kind of generic to 113 engines. Let me know.
After almost five years of trouble free performance, I have a significant issue......My ML55 (01) stalled twice, in town. Wouldn't restart until it cooled for five minutes. Then fine all the way home.
I went to the same place each time with identical behavior. So I idled it in the garage when it got to the same temp as in town 165f it stalled again. Seems to stall at the same temp each time.
Replaced the crank and cam sensors. Same issue. So, I looked to the coolant temp sensor. tried to wiggle it out and broke the plastic....flush with the engine.
Sorry to belabor this, but....anyone have any experience with a solution...?
P.S. if the post would be better off in a more general forum please let me know.
TIA all.....
TIA all.....
Oh Boy. Yes I just had this happen, and it’s difficult to get it out. Basically, I used some dental pics to essentially remove all the remaining plastic. What is then left is essentially the Outer Shell. In my case, it was for lack of a better word, fused to the block. Again I used the dental pics to carefully pry the edge around the casing and the block. This more or less mushrooms the casing enough to allow gentle pulls with needle nose pliers alternating from side to side, top bottom et
Thank you for the reply. If you don't mind.... were you prying against the bore with your picks ? I'm paranoid about scratches. If I'm not mistaken, the o ring / seal gets compressed when the clip is installed, so the bore may not be that critical. Obviously, I haven't seen the layout inside since mine is still in there... Did your sensor seal correctly...? In retrospect, do you see any other alternative means of extraction ? I'm also too paranoid to use an ez out, for the same reason.
Thanks again....
Cheers
