No fan with aircon.
Old Sep 13, 2025 | 10:32 PM
jimsfenc's Avatar
Audi A4, Merc ML270 CDI
No fan with aircon.
Good day, I have just purchased an ML270 CDI. When I had the aircon regassed the other day, the technician noticed that the cooling fan did not come on when the aircon was switched on. The Fan does work when the engine temp gets to about 85deg.C. The model is a Feb/2001 build. It appears that someone has modified the feed to the cooling fan by installing a separate relay for the aircon boost circuit. This may be because the small relays normally found in the fuse box are getting difficult to source in Australia. Obviously this modification is not working properly, there is no power to the pink or brown cables on the relay. I suspect that the wrong cables have been used. What I need to know is the position of terminal X22. Is this on the underside of the fuse box? The scanner shows "open circuit cooling fan" when the aircon is operating but there is no fault code with the aircon switched off. Thanks in advance Dave
Old Sep 16, 2025 | 01:50 AM
jimsfenc's Avatar
Ok I may have to answer my own questions. I have found a site where you can download mercedes dwf files for viewing in DesignReview. So far i have downloaded elecrical diagrams and legends but I'm sure there's a lot more stuff on there.
Old Sep 16, 2025 | 01:52 AM
jimsfenc's Avatar
Forgot to put link in. http://benz.ehost.tj/163/webetm/webetm/163/start.html
