W164 AUX / MP3 input socket in glovebox (Euro)
Old Sep 21, 2005 | 08:23 AM
benzmodz's Avatar
W203 slightly modified
Once you have removed the radio / COMAND (see navigation retrofit thread) the AUX cable plugs into the main hold block of the body harness and this one block attaches to the head unit.
Items needed.
- AUX cable
- 12 pin housing (same as C2 but shorter)
- MQS connector for 12 pin housing
- 4 MQS crimp pins
The connector clips into position very easily and quickly.
Remove cover panel (18mm velvet covered plug) from inside of the glovebox. With radio remove there is ample space to feel the location for the AUX plug to be inserted.
Clips into place the same way it does in all cars with the hole premade (same way as C-class). The actual pinout location is in the same position as that for the C-class also (in Euro models).
Should be a 15 min mod with parts in hand.
TR = Shield, BK = black. YE = yellow, BN = brown.
Or you can just order this part ....... 164 540 65 07 (W164 AUX cable)
not valid for Japan.
Old Sep 21, 2005 | 08:27 AM
benzmodz's Avatar
In the Euro head unit the AUX function is available when the AUDIO button is pressed.
In the Euro radio the AUX function is available when the CDC button is held for 5 seconds or until the AUX message appears on the display.
Old Nov 15, 2006 | 01:31 PM
CarlosMC's Avatar
C220CDi
Please,... any help ???? whare to plug the wire in an W164 ?? I ca't find it...
Old Nov 16, 2006 | 12:07 PM
CarlosMC's Avatar
C220CDi
By the way,... I have an audio 20 ...and ML350...
Old Nov 17, 2006 | 02:20 PM
CarlosMC's Avatar
C220CDi
can some one say if that's the same reference for european cars???
Old Nov 17, 2006 | 05:28 PM
Wolfgang's Avatar
MBs
Here's the iPod installation guide for North American models which might be similar:
http://www.alldata.com/tsb/Mercedes-...438/index.html
The part number I came up with for a Euro Audio 20 iPod kit for the W164 M-Class is B6 782 42 16. Hope this helps.
Old Dec 7, 2006 | 12:13 PM
CarlosMC's Avatar
C220CDi
and the reference for the aux input... not ipod???
thanks
Old Dec 7, 2006 | 04:01 PM
benzmodz's Avatar
thanks
The AUX is a plug and play setup. It clips into the main radio connector and then clips into the hole under the CD-stacker.
The only trick one needs to know is how to installthe glovebox side as that connector has a keyed tension ring that slides into the AUX input once it is in place and that will hold it in firmly.
Old Dec 8, 2006 | 03:25 AM
CarlosMC's Avatar
C220CDi
ok, it clips in the main radio connector.... and the other side in the glovebox... Correct,...But I need the reference of this wire or how to build it ... for an Audio 20 in ML350 in Spain..... pleaseee
Old Dec 8, 2006 | 05:46 PM
benzmodz's Avatar
It is just a normal part that you can order from any dealer.
Old Dec 11, 2006 | 02:23 AM
CarlosMC's Avatar
C220CDi
Thanks,... i know that but I need the wire reference,... my dealer can`t find it,...
Old Dec 12, 2006 | 12:06 PM
CarlosMC's Avatar
C220CDi
my dealer has found the wire.... Thankssss
