Tire Pressure Monitoring System
'97 C 280, '06 ML350
I can't seem to get the tire pressure to display. I hit the + button to reactivate, watch as it says tire pressure monitor being activated and then, it goes back to the screen which says tire pressure monitor may need to be reactivated. Is there something I am doing wrong?
Received 1,186 Likes
2020 GLE 450; 2023 BMW M2 Coupe
Tire pressure monitoring
ML 320 CDi
Hi,
In Europe/UK there's supposed to be an option for a 'proper' tyre pressure monitoring system which shows actual tyre pressures on dash. I ordered it, but typically, it doesn't appear to be available to fit yet (although it's in the brochure).
Cheers,
Cheers,
MBs
TPS systems
[QUOTE=Wolfgang]Here's a link describing both systems:
I don't think the direct-reading one has been offered in US MLs, has it? Maybe it will be offered in Europe because of the higher speeds? The indirect system takes several psi of change before it is detected.
MBs
W203 slightly modified
Originally Posted by Wolfgang
The direct-reading one is not yet available in Europe either, but "they are working on it" as far as I know. The indirect has some advantages since it works with any wheels, and is less sensitive if e.g. one side is exposed to the sun which may trigger the more sensitive direct reading system already.
The indirect system has one disadvantage in the ML. Excessive amounts of wheel spin in a dirt environment may cause some confusion over the true state of one tyre. Even then i cant see it being a problem.
