Couple of comments/questions
Old Oct 19, 2005 | 08:05 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Looked today to see where the cell/Tele Aid/GPS antenna was located. Could not find it. Anyone have a clue??
Also found thet the slot in between the cup holders is perfect for temp. storage of credit cards and receipts. Very handy but I do not know the actual purpose of it. I also do not know why they designed the cup holders so the the middle section between them can be lifted out. I do miss the dash cup holders on my W163. They were great.
Old Oct 19, 2005 | 08:30 PM
Wolfgang's Avatar
MBs
It's a multiple antenna module mounted under the rear part of the roof.
Old Oct 19, 2005 | 10:16 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Antenna location
[QUOTE=Wolfgang]It's a multiple antenna module mounted under the rear part of the roof.
Is it in the rear panel of the roof, or the rear lip spoiler?
Old Oct 19, 2005 | 10:20 PM
Console slot
I believe it's meant for storing parking garage tickets.
Old Oct 20, 2005 | 01:32 AM
Wolfgang's Avatar
MBs
It's under the rear roof panel.
Here's an article about MB antennas:
http://www.germancarfans.com/news.cf...ercedes/1.html
Old Oct 20, 2005 | 10:23 AM
Antenna location
That would explain why that is a separate panel from the rest of the roof. It must be plastic, then?
Old Oct 25, 2005 | 03:54 AM
whynot's Avatar
It's called the antenna roof module and yes it is mounted under the cover at the rear of the roof. It's made of fiberglass and is sealed on, so never try to remove it because it be ruined and have to be replace with a new one.
The cup holder divider is actually call "card holder" that's what it was designed to be. Both the U.S 164's & 251's have them, BUT the 251's have a bottle opener in the underside. Both are made to remove so you can then pull out the rubber bottom in the cup holders for easy clean up.
