"Check Engine" No, it is not the Gas Cap!
Old Mar 2, 2006 | 03:30 PM
jdr1000's Avatar
Hi guys, a new one here, my Check Engine light does not turn off after three days of checking the gas cap. It happened before a few times and the gas cap closure canceled the light but now that is not working.
3800 miles on the ML500.
any ideas?
J
Old Mar 2, 2006 | 07:42 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Only way to know for sure is to have the dealer pull the codes with the Star diagnostic computer. All else is a guess.
Old Mar 2, 2006 | 10:05 PM
jjl12's Avatar
'16 BMW X5 Xdrive 35i M Sport
Sosh is correct. I had the Check Engine light fairly recently, my problem was the fuel injector system was not working properly, which made the fuel mixture run too rich. They replaced some spark plugs and ran test, eventuallly getting the fuel mixture to the proper readings. Good luck.
Old Mar 3, 2006 | 11:24 AM
jangy's Avatar
2015 S212
Sounds like pressure. That could be a leak, the fuel pump, or lots of things. Should not be a big deal for the dealer to find. Hope it gets worked out quick, and keep us posted.
Old Mar 13, 2006 | 08:33 AM
jdr1000's Avatar
Gone
After 10 days , the Check Engine Light just turned itself off.
I will wait for my checkup to see if anything comes up.
Thks
