wheel offset and size
Old Jul 14, 2006 | 07:40 PM
weeeza's Avatar
ok now I found wheels on ebay that I really like
they come in 20x9.5 ET 35 all around
or 20x8.5 ET 32 all around
or 8.5 front 9.5 rear (same offsets as above)
I want to run 275/45/20 tires all around
will this work or will the wheels stick out of the car with this offset
which setup of wheels from these 3 options do you recommend, if any (with the mentioned tire size)
thanks
sam
Old Jul 14, 2006 | 08:37 PM
juank350's Avatar
ML350
i recommend 8.5 with 255 tires. since the offset is 32 i believe they will stick out about 1.5 cm in the front and maybe .5cm in the rear. I installed in my car 8.5 with offset 40 and stick out around .5cm in the front and nothing in the rear. in my opinion do not go with 275.
