Vehicle height question
Old Sep 4, 2006 | 12:30 AM
Learso's Avatar
2009 GL450, 2009 G55 Mocha Black with Cognac Interior, 08 911 Turbo Cab, 08 CLK63 Black Series
I am a new owner of the new ML500 and recently noticed that the driver's side of the vehicle looked slightly higher than the passenger's side....so I grabbed the messuring tape and went around the car with it. Sure enough the driver's side was about .5 inch higher at both front and back tires. Any clue as to why this is? This seems very odd to me.
One more help questions. The mechanic that fixed my driver's side headlight left the light beaming a bit too high relative to the other side. Is there any easy way to adjust beam level without taking it in to the dealer?
Thank you for the help,
Learso
Old Sep 4, 2006 | 04:12 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
If you have Airmatic there may be a problem with a sensor. As for the headlight adjustment go to the dealer. You are under warranty and this should be covered.
Old Sep 4, 2006 | 06:50 PM
Learso's Avatar
Ya, I guess I will have to go to the dealer. It's just that I have 4 Mercedes and, with my Kleemann CLK55K, I am there more than I want. But I think that you are right, I will take it it.
Has anyone measured the height to see if this is an isolated issue?
Learso.
