Would tinting the front two windows interfere with Nav/Radio system?
You will not have any problem. I live in Arizona and had my front two windows tinted right after making the purchase. My MB dealership also offered me the same service. It is illegal in AZ to tint the front windshield and that is the only way I could see that the navigation system would be affected.
2013 ML350 BLUETEC/2012 SLK350/2000 C280/1972 28SE
It shouldn't interfere with the Nav/Radio reception however before you tint the windows, I'd check on the legality of tinting the front windows in your state. In numerous states it is against the law to tint these windows (prohibiting a law officer from looking in at a traffic stop) and several states will actually make you scrape off the tinting if you want to drive the vehicle again after paying a hefty fine.
Cee Fiddy Five
Just take a picture of the car before you tint.
Around here there isn't a fine, you just have to prove that you untinted...so just bring to court the untinted pics and you are good to go (worked for my friend so).
Received 1,182 Likes
2020 GLE 450; 2023 BMW M2 Coupe
AM/FM antenna
Did yous see my post above? AM/FM/WB antenna is in the same module as the other antennas under the roof panel, not the back window, I beleve. But you're the tech, so prove me wrong, and I'll slink away.
MBs
http://ppd.delphi.com/pdf/ppd/audio/ant_multiple.pdf
